Fullscreen "Multiview" Not Working
Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
 VMIX BUG.png (17kb) downloaded 3 time(s).When I click on "Input 1" or "Multiview", the V-MIX not change the option. Always on "Output" and I can't change.
Joined: 4/16/2017(UTC) Views messages in topic : 578 Location: jamaica
I have the same problem on a system I just set up for our Horse Racing track....it is only showing "Fullscreen", and I can not select other outputs as before....They want to use the multiview output for the person who is switching, as that person is sitting about 6 feet from the main screen, and is using an El Gato for the switching....I had everything working perfect before, but this issue arose after an update to 23.0.0.62...
 1 user thanked Joeboe for this useful post.
Originally Posted by: Joeboe  I have the same problem on a system I just set up for our Horse Racing track....it is only showing "Fullscreen", and I can not select other outputs as before....They want to use the multiview output for the person who is switching, as that person is sitting about 6 feet from the main screen, and is using an El Gato for the switching....I had everything working perfect before, but this issue arose after an update to 23.0.0.62... Exacly!!!
I updated to 23.0.0.64, and it seems to be working again....try updating.....
Joined: 4/29/2015(UTC) Posts: 8   Location: Montreal, Canada Thanks: 1 times
We have the same issue after upgrading to 23.0.0.64 but we were fine in 23.0.0.62!
Anyone found a solution?
I do not know , but go to output settings, select output 1 as multiview, and output 2 as anything....just make sure that something is selected, close, and restart vmix....tell me if that works....if not, go to fullscreen first, and then try again......I do not know, but I did that and it works now....I wonder if it will keep working now that I shut down my system....sometimes windows just does some crap to a PC...
Joined: 5/4/2020(UTC) Posts: 4   Location: muiderberg Was thanked: 1 time(s) in 1 post(s)
I've suddenly the same problem! I've tried the solutions but didnt work...
Same problem here.
Fullscreen view is always showing output. It is not possible to select anything else. It always switches back to output, no matter what you select.
I'm on 23.0.0.67.
Cheers
pro
I've found the "bug" that is causing this issue:
If you switch the source of output 1 in "Output / NDI / SRT Settings" (NOT THE FULLSCREEN OUTPUTS ABOVE! BUT THE FIRST IN THE $ OUTPUTS BELOW!) to something else than "output" (for example to the input number of mix 2 if you have a second mix/effect output) the multiview isn't available anymore for fullscreen output. If you switch output 1 back to "Output" (the first m/e) the fullscreen output works again.
Seems to be a bug!?
Martin, can you check that please? It happens on the preview version 24 too.
Cheers
pro.
Joined: 3/28/2021(UTC) Posts: 5  Location: Franklin, TN
This is still a bug in 24.0.0.52. If I have an input selected as the source of Output 1, the Fullscreen 1 will no longer display a multiview.
Joined: 1/13/2010(UTC) Posts: 5,312  Location: Gold Coast, Australia Was thanked: 4708 time(s) in 1613 post(s)
This is not a bug and is a technical requirement of vMix. To explain, the primary purpose of vMix is to mix the output so if you change both Fullscreen or Output 1 to something else then that output cannot be processed.
The Outputs 2-4 are intended for auxiliary outputs that are different, so use those and keep Output 1 or Fullscreen 1 as Output.
Thanks for the info. In the situation where I came across this the output was irrelevant, I was using the multi-corder to ISO record Caller inputs by routing them through the outputs then into the multi-corder. I was hoping to have use the multi-view display on a Fullscreen output to monitor the 4 inputs. I guess in this situation I just can't use the multi-view.
.They want to use the multiview output for the person who is switching, as that person is sitting about 6 feet from the main screen, and is using an El Gato for the switching.... vidmate mobdro
