wmsenna
#1 Posted : Wednesday, September 30, 2020 11:53:56 PM(UTC)
wmsenna
VMIX BUG.png (17kb) downloaded 3 time(s).
When I click on "Input 1" or "Multiview", the V-MIX not change the option. Always on "Output" and I can't change.
Joeboe
#2 Posted : Thursday, October 1, 2020 12:07:19 AM(UTC)
Joeboe
I have the same problem on a system I just set up for our Horse Racing track....it is only showing "Fullscreen", and I can not select other outputs as before....They want to use the multiview output for the person who is switching, as that person is sitting about 6 feet from the main screen, and is using an El Gato for the switching....I had everything working perfect before, but this issue arose after an update to 23.0.0.62...
thanks 1 user thanked Joeboe for this useful post.
wmsenna on 10/1/2020(UTC)
wmsenna
#3 Posted : Thursday, October 1, 2020 5:09:51 AM(UTC)
wmsenna
Exacly!!!
Joeboe
#4 Posted : Tuesday, October 6, 2020 1:27:08 AM(UTC)
Joeboe
I updated to 23.0.0.64, and it seems to be working again....try updating.....
productionsoomf
#5 Posted : Tuesday, October 6, 2020 7:00:04 AM(UTC)
productionsoomf
Canada
We have the same issue after upgrading to 23.0.0.64 but we were fine in 23.0.0.62!
Anyone found a solution?
Joeboe
#6 Posted : Tuesday, October 6, 2020 7:38:26 AM(UTC)
Joeboe
I do not know , but go to output settings, select output 1 as multiview, and output 2 as anything....just make sure that something is selected, close, and restart vmix....tell me if that works....if not, go to fullscreen first, and then try again......I do not know, but I did that and it works now....I wonder if it will keep working now that I shut down my system....sometimes windows just does some crap to a PC...
synco
#7 Posted : Thursday, December 31, 2020 12:38:05 AM(UTC)
synco
Netherlands
I've suddenly the same problem! I've tried the solutions but didnt work...
streaming---pro
#8 Posted : Tuesday, January 26, 2021 12:10:38 AM(UTC)
streaming---pro
Germany
Same problem here.
Fullscreen view is always showing output. It is not possible to select anything else. It always switches back to output, no matter what you select.
I'm on 23.0.0.67.
Cheers
pro
streaming---pro
#9 Posted : Tuesday, January 26, 2021 2:50:34 AM(UTC)
streaming---pro
Germany
I've found the "bug" that is causing this issue:
If you switch the source of output 1 in "Output / NDI / SRT Settings" (NOT THE FULLSCREEN OUTPUTS ABOVE! BUT THE FIRST IN THE $ OUTPUTS BELOW!) to something else than "output" (for example to the input number of mix 2 if you have a second mix/effect output) the multiview isn't available anymore for fullscreen output. If you switch output 1 back to "Output" (the first m/e) the fullscreen output works again.
Seems to be a bug!?
Martin, can you check that please? It happens on the preview version 24 too.
Cheers
pro.
dtmmedia
#10 Posted : Thursday, April 1, 2021 11:26:03 PM(UTC)
dtmmedia
This is still a bug in 24.0.0.52. If I have an input selected as the source of Output 1, the Fullscreen 1 will no longer display a multiview.
#11 Posted : Friday, April 2, 2021 1:51:42 AM(UTC)
This is not a bug and is a technical requirement of vMix.
To explain, the primary purpose of vMix is to mix the output so if you change both Fullscreen or Output 1 to something else
then that output cannot be processed.
The Outputs 2-4 are intended for auxiliary outputs that are different, so use those and keep Output 1 or Fullscreen 1 as Output.
dtmmedia
#12 Posted : Monday, April 19, 2021 2:16:14 PM(UTC)
dtmmedia
Thanks for the info. In the situation where I came across this the output was irrelevant, I was using the multi-corder to ISO record Caller inputs by routing them through the outputs then into the multi-corder. I was hoping to have use the multi-view display on a Fullscreen output to monitor the 4 inputs. I guess in this situation I just can't use the multi-view.
ashishkumarji
#13 Posted : Monday, April 19, 2021 10:44:50 PM(UTC)
ashishkumarji
.They want to use the multiview output for the person who is switching, as that person is sitting about 6 feet from the main screen, and is using an El Gato for the switching.... vidmate mobdro
