audio problems with Blackmagic card Broadway tabernacle
Joined: 10/4/2020(UTC) Posts: 3  Location: Orangeville
Hi Working with this church and the output out of vmix is not clean- almost sounds compressed. Strong computer and graphics card. Audio from sound console is clean , goes into mic in of computer, SDI video goes into a SDI blackmagic card.
Hi
No, dont have access to a USB audio device. cannot feed audio into blackmagic as it has no audio in. would have to get a SDI decoder to do that
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: JohnDev  goes into mic in of computer If your computer also has a Line In, try that. If this does not give better results you could connect the mixer to the Line In of (one of) your camera(s).
Originally Posted by: JohnDev  Hi
No, dont have access to a USB audio device. cannot feed audio into blackmagic as it has no audio in. would have to get a SDI decoder to do that Which Blackmagic card do you have? Even the Intensity Pro has analog audio inputs. But dmwkr's solution should work well unless your cameras don't have mic input jacks.
Hi the church has the Decklink 4k SDI capture card - no audio inputs or breakout cables to bring audio in. Have moved to line in of the computer and see how it is ; other than that might move to a SDI audio embed unit such as a daC-91.
