Anyway to create media list with transition effect?
Joined: 7/7/2020(UTC) Posts: 10  Location: Cần Thơ Thanks: 8 times
I'm using virtual set with TV screen. I want to add videos/images list on the TV screen. But the "List" input type does not have transition effect. Please show me anyway to create media list with transition effect on VMIX. PS:I'm using air mouse as wireless keyboard so I able to control the list or slideshow manually.  G20-Air-Mouse-Gyro-.png (299kb) downloaded 2 time(s). QA1.jpg (211kb) downloaded 2 time(s).
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
playlist can do transition effects
Originally Posted by: doggy  playlist can do transition effects But playlist unable to add to Virtual set's screen
Joined: 4/23/2017(UTC) Posts: 1,481  Location: Germany Thanks: 3 times Was thanked: 196 time(s) in 176 post(s)
You can use the output of a mini mix as input for the TV screen. Any source can be used for a mini mix. Mini mix offers cut and fade.
 1 user thanked mavik for this useful post.
Originally Posted by: tttin46  Originally Posted by: doggy  playlist can do transition effects But playlist unable to add to Virtual set's screen Wel that'' s not he function of a playlist either :-) as mentioned use Vmix inputs then , or replace inputs though shortcuts/triggers, maybe even scripts BTW why would you use transitions with virtual sets ?
Originally Posted by: mavik  You can use the output of a mini mix as input for the TV screen. Any source can be used for a mini mix. Mini mix offers cut and fade.
What is Mini mix? You mean external videos switch?
Originally Posted by: doggy  Originally Posted by: tttin46  Originally Posted by: doggy  playlist can do transition effects But playlist unable to add to Virtual set's screen Wel that'' s not he function of a playlist either :-) as mentioned use Vmix inputs then , or replace inputs though shortcuts/triggers, maybe even scripts BTW why would you use transitions with virtual sets ? Transition on TV screen in Virtual set will reduce flicker when I change TV screen's content
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 65 Location: Canada
Thanks: 1 times Was thanked: 20 time(s) in 19 post(s)
The Mix Input is available in the vMix 4K and vMix Pro editions: https://www.vmix.com/help23/Mix.htmlOf note, it can only be added from the "Add Input" dropdown/pop-up Window. vMixGreg
 1 user thanked vmixgreg for this useful post.
