tttin46
#1 Posted : Monday, October 5, 2020 7:22:48 PM(UTC)
tttin46
Viet Nam
I'm using virtual set with TV screen. I want to add videos/images list on the TV screen. But the "List" input type does not have transition effect. Please show me anyway to create media list with transition effect on VMIX.
PS:I'm using air mouse as wireless keyboard so I able to control the list or slideshow manually.
#2 Posted : Monday, October 5, 2020 7:56:23 PM(UTC)
playlist can do transition effects
tttin46
#3 Posted : Monday, October 5, 2020 8:38:22 PM(UTC)
tttin46
Viet Nam
But playlist unable to add to Virtual set's screen
mavik
#4 Posted : Monday, October 5, 2020 8:46:38 PM(UTC)
mavik
You can use the output of a mini mix as input for the TV screen. Any source can be used for a mini mix. Mini mix offers cut and fade.
tttin46 on 10/5/2020(UTC)
#5 Posted : Monday, October 5, 2020 8:49:39 PM(UTC)
Wel that'' s not he function of a playlist either :-)
as mentioned use Vmix inputs then , or replace inputs though shortcuts/triggers, maybe even scripts
BTW why would you use transitions with virtual sets ?
tttin46
#6 Posted : Monday, October 5, 2020 9:12:06 PM(UTC)
tttin46
Viet Nam
What is Mini mix? You mean external videos switch?
tttin46
#7 Posted : Monday, October 5, 2020 9:18:54 PM(UTC)
tttin46
Viet Nam
Transition on TV screen in Virtual set will reduce flicker when I change TV screen's content
vmixgreg
#8 Posted : Wednesday, October 7, 2020 12:08:06 AM(UTC)
vmixgreg
Rank: Staff
Groups: Registered, Moderator
Was thanked: 22 time(s) in 21 post(s)
The Mix Input is available in the vMix 4K and vMix Pro editions:
https://www.vmix.com/help23/Mix.html
Of note, it can only be added from the "Add Input" dropdown/pop-up Window.
vMixGreg
thanks 1 user thanked vmixgreg for this useful post.
tttin46 on 10/7/2020(UTC)
