Joined: 12/20/2017(UTC) Posts: 30  Location: Raleigh, NC Thanks: 7 times
I've been designing a panel for a job, and last week it looked fine on my tablet, but today the entire panel is much smaller. How can I enlarge it?
Joined: 8/5/2017(UTC) Posts: 582  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
I'm assuming you are referring to the vMix Panel Builder app ? A new version was uploaded yesterday to the Google Play Store yesterday. There may have been some changes in the APK that affects some tablets. It seems to work OK on a Galaxy Tab S6. What type of tablet are you using ?
Richard
Sorry, yes...I'm referring to vMix Panel Builder. I got the update. I have 1.0.3 Build 1. My tablet is a Huawei M5. Here's a screenshot.  I'ts not obvious from the screenshot, but the screen assets are much smaler than before. They used to take up nearly the entire tablet screen. I'm guess I just need to scale everything up in the Editor.
Another issue I'm noticing is that I'm not able to type in Width and Height. Right now the buttons are 70 x 70, and when I changed to 100 x 100, nothing happens. However, I can type in 101 for each and then hit the down arrow once to decrease to 100, the new size is accepted.
That seems unusual. I can't duplicate that issue. When you type in the value, you must hit enter in the field to change the value...
Note: If you plan to use 100x100 as a default, you can set it in the preferences if you like, then save it.
BTW: Can you post further discussions regarding the app in the vMix Panel Builder thread. That will avoid multiple threads on the same app.
Thanks sebrame, Richard
