sebrame
#1 Posted : Thursday, October 1, 2020 10:33:44 PM(UTC)
sebrame
I've been designing a panel for a job, and last week it looked fine on my tablet, but today the entire panel is much smaller. How can I enlarge it?
raugert
#2 Posted : Friday, October 2, 2020 2:43:48 AM(UTC)
raugert
Canada
I'm assuming you are referring to the vMix Panel Builder app ? A new version was uploaded yesterday to the Google Play Store yesterday. There may have been some changes in the APK that affects some tablets. It seems to work OK on a Galaxy Tab S6. What type of tablet are you using ?
Richard
sebrame
#3 Posted : Friday, October 2, 2020 5:39:03 AM(UTC)
sebrame
Sorry, yes...I'm referring to vMix Panel Builder. I got the update. I have 1.0.3 Build 1.
My tablet is a Huawei M5. Here's a screenshot.
Screenshot of Panel Builder
I'ts not obvious from the screenshot, but the screen assets are much smaler than before. They used to take up nearly the entire tablet screen. I'm guess I just need to scale everything up in the Editor.
sebrame
#4 Posted : Friday, October 2, 2020 5:48:57 AM(UTC)
sebrame
Another issue I'm noticing is that I'm not able to type in Width and Height. Right now the buttons are 70 x 70, and when I changed to 100 x 100, nothing happens. However, I can type in 101 for each and then hit the down arrow once to decrease to 100, the new size is accepted.
raugert
#5 Posted: : Friday, October 2, 2020 10:42:53 AM(UTC)
raugert
Canada
That seems unusual. I can't duplicate that issue. When you type in the value, you must hit enter in the field to change the value...
Note: If you plan to use 100x100 as a default, you can set it in the preferences if you like, then save it.
BTW: Can you post further discussions regarding the app in the vMix Panel Builder thread. That will avoid multiple threads on the same app.
Thanks sebrame,
Richard
