Hardware Compatibility
UMC ASIO hardware Audio output not working for bus
I have a UMC 1820 and I am using it as an input device for microphones into Vmix. This is working perfectly. I want to use audio busses to send a specific microphone out to an output. When i sed up an audio bus and select an output it does not send any audio to the umc1820 output channels. If i select the same output name in windows and set it as the default it works just fine and sends out the master and also is able to send out audio from youtube and other local audio sources. Not sure why VMIX is unable to send to the output Any help would be greatly appreciated.
Thanks: 3 times Was thanked: 20 time(s) in 19 post(s)
here is the basic setup to double check..
set the buss outputs to the preferred ASIO driver outputs in vmix settings.. make sure you have audio signal being routed to those busses in the vmix mixer.. Also make sure you have turned on the buss channel (i think channels are off by default ?) and that the channel isnt muted and fader is up.. At that point you should get signal at the outputs on the interface.. if you dont hear anything and the UMC comes with its own mixer software then check to see if its showing a signal on those outputs in the UMC mixer and verify nothing is muted or no faders are down..
I think i have all the settings correct. I attached pictures showing the config i have. Just realized i circled bus G but i meant to circle Bus F in the image.  audio mixer.PNG (110kb) downloaded 0 time(s). settings.PNG (44kb) downloaded 1 time(s).
I think i found the issue. I uninstalled the driver. I was running 4.59 which is latest. I then installed 4.38 and it is now working... TY for your help.
