Simsyuk
#1 Posted : Thursday, September 24, 2020 8:50:13 AM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
I've come up with a new show idea for my channel and I wish to place the guests windows at an angle but I can't see if this is possible within vMix.
I've added an image to give you a better understanding what I would like to do (box 1 to 4) will be my guests).
If this is possible would you be so kind as to point me in the right direction (I've tried the Multiview templates but none are any good for what I need).
Thanks.
#2 Posted : Thursday, September 24, 2020 3:56:10 PM(UTC)
Sure it can be done
Play with position - rotate (x,y,z) option of inputs
Simsyuk
#3 Posted : Thursday, September 24, 2020 7:51:24 PM(UTC)
Simsyuk
Originally Posted by: doggy Go to Quoted Post
Sure it can be done
Thanks doggy, I tried that but I couldn't get it to fix the position I wanted.
spino
#4 Posted : Thursday, September 24, 2020 9:14:28 PM(UTC)
spino
Rank:: Advanced Member
Italy
Was thanked: 21 time(s) in 13 post(s)
The first idea I have is to create two multiview input. In the first one you can put four inputs (as in your picture) and in the second one you can select two inputs: in the first one put the first multiview you can position as you want and in the second one put the talent.
#5 Posted : Thursday, September 24, 2020 9:16:17 PM(UTC)
Sure it can be done
What is the exact problem you have with the position ?
Simsyuk
#6 Posted : Saturday, September 26, 2020 8:00:26 AM(UTC)
Simsyuk
Sure it can be done
I couldn't get the far side to fix to the position I wanted, it's a shame vMix doesn't have a feature where you can click and drag to position (a bit like PS resize).
#7 Posted : Saturday, September 26, 2020 8:30:36 AM(UTC)
AHA, it worked but not fully satisfactory :-)
Haven't mentioned it (Yet) but you could use a UVmap(s) in a virtual set transformed exactly to the size and position you want to place that input in (use Gimp to edit the UV maps on top of a screenshot for reference)
Simsyuk
#8 Posted : Saturday, September 26, 2020 8:40:42 AM(UTC)
Simsyuk
I get your thinking there, the inputs would be live video/camera inputs so I don't think it would work -it's more of a perspective view.
I've added the idea in new features section, hopefully Martin can look into this, personally I think this would be a great idea if this could be added, think of the endless possibilities where you want to place and shape the live inputs!
#9 Posted : Saturday, September 26, 2020 9:02:50 AM(UTC)
That would work perfectly. in PS or Gimp one can make a perspective look of an image, curve it, round corners etc
Simsyuk
#10 Posted : Saturday, September 26, 2020 12:50:32 PM(UTC)
Simsyuk
Thanks Doggy, yeap its all working great. Once done I'll post a screen shot to show you.
Thanks again, you've been a great help.
