Joined: 8/16/2019(UTC) Posts: 357  Thanks: 80 times Was thanked: 24 time(s) in 19 post(s)
I've come up with a new show idea for my channel and I wish to place the guests windows at an angle but I can't see if this is possible within vMix. I've added an image to give you a better understanding what I would like to do (box 1 to 4) will be my guests). If this is possible would you be so kind as to point me in the right direction (I've tried the Multiview templates but none are any good for what I need).  presenter-angle.jpg (249kb) downloaded 6 time(s).Thanks.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Sure it can be done Play with position - rotate (x,y,z) option of inputs
Originally Posted by: doggy  Sure it can be done Play with position - rotate (x,y,z) option of inputs Thanks doggy, I tried that but I couldn't get it to fix the position I wanted.
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
The first idea I have is to create two multiview input. In the first one you can put four inputs (as in your picture) and in the second one you can select two inputs: in the first one put the first multiview you can position as you want and in the second one put the talent.
Originally Posted by: Simsyuk  Originally Posted by: doggy  Sure it can be done Play with position - rotate (x,y,z) option of inputs Thanks doggy, I tried that but I couldn't get it to fix the position I wanted. What is the exact problem you have with the position ?
Originally Posted by: doggy  Originally Posted by: Simsyuk  Originally Posted by: doggy  Sure it can be done Play with position - rotate (x,y,z) option of inputs Thanks doggy, I tried that but I couldn't get it to fix the position I wanted. What is the exact problem you have with the position ? I couldn't get the far side to fix to the position I wanted, it's a shame vMix doesn't have a feature where you can click and drag to position (a bit like PS resize).
Quote:I couldn't get the far side to fix to the position I wanted, it's a shame vMix doesn't have a feature where you can click and drag to position (a bit like PS resize). AHA, it worked but not fully satisfactory :-) Haven't mentioned it (Yet) but you could use a UVmap(s) in a virtual set transformed exactly to the size and position you want to place that input in (use Gimp to edit the UV maps on top of a screenshot for reference)
Originally Posted by: doggy  Quote:I couldn't get the far side to fix to the position I wanted, it's a shame vMix doesn't have a feature where you can click and drag to position (a bit like PS resize). AHA, it worked but not fully satisfactory :-) Haven't mentioned it (Yet) but you could use a UVmap(s) in a virtual set transformed exactly to the size and position you want to place that input in (use Gimp to edit the UV maps on top of a screenshot for reference) I get your thinking there, the inputs would be live video/camera inputs so I don't think it would work -it's more of a perspective view. I've added the idea in new features section, hopefully Martin can look into this, personally I think this would be a great idea if this could be added, think of the endless possibilities where you want to place and shape the live inputs!
Quote:I get your thinking there, the inputs would be live video/camera inputs so I don't think it would work -it's more of a perspective view. That would work perfectly. in PS or Gimp one can make a perspective look of an image, curve it, round corners etc  uvtest.jpg (118kb) downloaded 1 time(s).
Originally Posted by: doggy  Quote:I get your thinking there, the inputs would be live video/camera inputs so I don't think it would work -it's more of a perspective view. That would work perfectly. in PS or Gimp one can make a perspective look of an image, curve it, round corners etc Thanks Doggy, yeap its all working great. Once done I'll post a screen shot to show you. Thanks again, you've been a great help.
