List file play automatically
Joined: 12/20/2012(UTC) Posts: 81  Location: INDIA, TAMILNADU Thanks: 5 times Was thanked: 8 time(s) in 6 post(s)
play list file when play first file automatically play 2nd file, then stop. when play 3rd file,automatically play 4th file, then stop.
this problem from vmix 12. vmix 11 perfect
Joined: 1/13/2010(UTC) Posts: 5,322  Location: Gold Coast, Australia Was thanked: 4726 time(s) in 1618 post(s)
Hi, Please create a preset in vMix of your playlist and email it to us at info@vmix.com.auAlso let me know the exact version of vMix 12 and if you are using x64 or x86. If you could create a recording demonstrating the issue that would also help. Regards, Martin vMix
my Video list qta files all each 4-seconds. we are try vmix 12.X.X.X 64-bit check :
Thankyou,
I have looked at the video and the preset files provided. Have you disabled automatically play next item under the List -> Edit Items menu?
Note that the stinger transition is only designed to be used with Image Sequences, and not the List input as the timing is not exact for video clips.
Martin vMix
admin wrote:Thankyou,
Martin vMix the same preset work good vmix 32-bit ( version 11, 12 ) the problem only 64-bit. just i asking martin, 32-bit work good. but, 64-bit have bug. the same time 64-bit purpose? what is the different between vmix 32-bit & 64-bit?
I'm guessing it is to do with the duration you have set on the stinger. The timing of it is not going to match the video 100% of the time.
My guess is the time it takes for the video to start playing is slightly shorter in 32bit.
admin wrote:I'm guessing it is to do with the duration you have set on the stinger. The timing of it is not going to match the video 100% of the time.
My guess is the time it takes for the video to start playing is slightly shorter in 32bit. i try to this. but, the same problem. please, try to solve this problem in 64-bit thanku
As mentioned, stingers with video list is not supported as the timing is not exact. This is not a problem that can be fixed, you will need to use Image Sequence or separate video inputs instead.
martin vMix
