amsudeen
#1 Posted : Saturday, February 22, 2014 10:48:13 PM(UTC)
amsudeen
Was thanked: 8 time(s) in 6 post(s)
play list file when play first file automatically play 2nd file, then stop. when play 3rd file,automatically play 4th file, then stop.
this problem from vmix 12. vmix 11 perfect
#2 Posted : Sunday, February 23, 2014 5:26:56 AM(UTC)
Was thanked: 4718 time(s) in 1616 post(s)
Please create a preset in vMix of your playlist and email it to us at info@vmix.com.au
Also let me know the exact version of vMix 12 and if you are using x64 or x86.
If you could create a recording demonstrating the issue that would also help.
amsudeen
#3 Posted : Tuesday, February 25, 2014 12:45:40 AM(UTC)
amsudeen
my Video list qta files all each 4-seconds.
we are try vmix 12.X.X.X 64-bit
check :
#4 Posted : Wednesday, February 26, 2014 5:30:39 AM(UTC)
Thankyou,
I have looked at the video and the preset files provided.
Have you disabled automatically play next item under the List -> Edit Items menu?
Note that the stinger transition is only designed to be used with Image Sequences, and not the List input
as the timing is not exact for video clips.
amsudeen
#5 Posted : Wednesday, February 26, 2014 8:36:13 AM(UTC)
amsudeen
admin wrote:
Thankyou,
the same preset work good vmix 32-bit ( version 11, 12 )
the problem only 64-bit.
just i asking martin, 32-bit work good. but, 64-bit have bug.
the same time 64-bit purpose?
what is the different between vmix 32-bit & 64-bit?
#6 Posted : Wednesday, February 26, 2014 9:42:52 AM(UTC)
I'm guessing it is to do with the duration you have set on the stinger.
The timing of it is not going to match the video 100% of the time.
My guess is the time it takes for the video to start playing is slightly shorter in 32bit.
amsudeen
#7 Posted : Thursday, February 27, 2014 12:40:32 AM(UTC)
amsudeen
i try to this. but, the same problem.
please, try to solve this problem in 64-bit
thanku
#8 Posted : Thursday, February 27, 2014 3:28:22 AM(UTC)
As mentioned, stingers with video list is not supported as the timing is not exact.
This is not a problem that can be fixed, you will need to use Image Sequence or separate video inputs instead.
martin
#9 Posted : Sunday, March 2, 2014 7:17:57 AM(UTC)
There was a fix relating to MOV and List below:
http://forums.vmix.com.au/default.aspx?g=posts&m=8401#post8401
It doesn't seem likely it will fix your issue, but no harm in trying.
amsudeen
#10 Posted : Sunday, March 2, 2014 8:44:14 AM(UTC)
amsudeen
thanku, thanku, thanku
