Plamen
#1 Posted : Monday, July 13, 2020 10:44:10 AM(UTC)
Plamen
Hey all,
I am new to using the GT title designer as I've normally used other means for adding graphics to my show, but now I've come to a point where I needed some simple GT titles.
The effect I'm trying to achieve is a merge from 2 boxes to 3 boxes. Each box has a title in it which is layered via an Input Multiview. The issue comes when I hit 'merge', all of the GT titles animate on screen even though they were all already active.
Is there a way to disable this behavior?
Thanks in advance!
xemles
#2 Posted : Friday, September 25, 2020 10:51:39 PM(UTC)
xemles
France, Metropolitan
Got the exact same issue... Have you found a way to fix that?
#3 Posted : Friday, September 25, 2020 11:52:12 PM(UTC)
Make them without animations ?
xemles
#4 Posted : Saturday, September 26, 2020 12:59:51 AM(UTC)
xemles
But we still want the animations when we make them get in the first time
#5 Posted : Saturday, September 26, 2020 1:28:21 AM(UTC)
Seems to be an either or situation
but if it's really important trigger to replace the animated title with a static version (slight delay)
Yes i do realize this means more inputs , but that's a workaround
Nathan232
#6 Posted : Saturday, May 14, 2022 12:41:42 AM(UTC)
Nathan232
Don't use transition in or transition out in the animations.
Instead uses the pages animations to animate the title and you can control them using triggers.
Hope this helps
