GT
How to stop GT titles from animating after merge transition
Hey all,
I am new to using the GT title designer as I've normally used other means for adding graphics to my show, but now I've come to a point where I needed some simple GT titles.
The effect I'm trying to achieve is a merge from 2 boxes to 3 boxes. Each box has a title in it which is layered via an Input Multiview. The issue comes when I hit 'merge', all of the GT titles animate on screen even though they were all already active.
Is there a way to disable this behavior?
Thanks in advance!
Joined: 11/25/2019(UTC) Posts: 43  Location: Bordeaux Was thanked: 2 time(s) in 2 post(s)
Got the exact same issue... Have you found a way to fix that?
Make them without animations ?
Originally Posted by: doggy  Make them without animations ? But we still want the animations when we make them get in the first time
Seems to be an either or situation
but if it's really important trigger to replace the animated title with a static version (slight delay) Yes i do realize this means more inputs , but that's a workaround
Don't use transition in or transition out in the animations.
Instead uses the pages animations to animate the title and you can control them using triggers. Hope this helps
GT
