Howdy. I wonder if anyone has seen this or it it's a bug (I will post on the vMix forum too). I have shortcuts setup to have my number pad select inputs 1-9 into preview. Works great. However, I just noticed that if I have a 'Mix' input, and make a change to either the preview or program input on the Mix input, from that point on, pressing a number pad key not only changes the main preview window to that input (as normal) but ALSO changes either the preview or program on that MIX input to the selected input. That shouldn't happen. The input selected on the MIX input shouldn't change with the number pad keys at all. This keeps happening unless I select the 'gear' icon in the mix input and then close the settings box. Then the number pad reverts to it's correct activity of just changing the main 'preview' bus, and not changing anything in the mix input. Anyone else see this? Any thoughts on fixing/stopping this from happening? Thanks! Best, Ben Benjamin Freedman PrimeImage Media 480-399-0000 - direct 480-240-9270 - office 866-549-6051 - fax ben@PrimeImageMedia.comwww.PrimeImageMedia.com
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Using the number pad for shortcuts isn't a good choice unfortunately as Windows automatically assigns these numbers to select items in a dropdown box, hence why the Mix input dropdown box is changing. Clicking a menu or opening a window will deactivate this selection by Windows, and is the only workaround at this time.
