Plamen
#1 Posted : Saturday, September 12, 2020 3:54:02 AM(UTC)
Plamen
Hello all,
I am integrating some stinger transitions into a show and they were originally delivered as MOVs. Obviously I needed to convert this to a PNG sequence, but when I compared the usage of the 2 inputs, the MOV added about 3% of GPU Memory usage and the PNG sequence added about 10% GPU Memory usage?
Does this GPU Memory usage check out from what you all have seen? My instinct tells me that a PNG sequence should use less power than an MOV because it does not need to be decoded.
Thanks!
Vince Beck
#2 Posted : Sunday, September 13, 2020 12:41:42 PM(UTC)
Vince Beck
PNG sequence should defintely use less processing. In fact I even use 10 second sequences for background animations on PIPs VS Video files for that very reason. The processing you are seeing may be temporary when the file is first read.
It also depends on the GPU and processor used.
mikebrown
#3 Posted : Wednesday, September 16, 2020 4:08:54 AM(UTC)
mikebrown
Rank:: Newbie
It seems like this would be the case, but in my experience image sequence inputs take up DRASTICALLY more GPU memory than MOV's. I've seen this behavior across several vMix installations/hardward.
Kelvin
#4 Posted : Wednesday, September 16, 2020 4:15:42 AM(UTC)
Kelvin
I'm pretty sure PNG sequences are preloaded into GPU Memory. That's why you are seeing an uptick in the GPU Memory usage. This way, they are ready to go and use very little processing power when played.
