rowby
#1 Posted : Wednesday, October 11, 2017 12:48:21 PM(UTC)
rowby
Hi all,
Is it possible to clone or copy an existing input?
I have a nice input set up and I'd rather not have to "start all over" when I want to create a slightly different version of the input.
Using Vmix 20
Thanks!
Rowby
stevespaw
#2 Posted : Wednesday, October 11, 2017 1:11:48 PM(UTC)
stevespaw
Was thanked: 75 time(s) in 57 post(s)
This is not immediately obvious, but I just create a virtual clip and then rename the new one.
This may be what you need.
Steve
sinc747
#3 Posted : Wednesday, October 11, 2017 1:22:56 PM(UTC)
sinc747
Was thanked: 200 time(s) in 166 post(s)
To expand on what Steve posted...
Rt click the settings icon on the Input you want to copy and select "Create Virtual Input." This works and make a "copy" of almost all inputs. I don't think is "copies" video files, but rather allows the new input to display what is playing in the original input.
Hope this helps.
- Tom
stevespaw
#4 Posted : Thursday, October 12, 2017 10:03:36 AM(UTC)
stevespaw
Thanks Tom,
Much better detail.
To add, the trick is to rename the new "virtual input" on the setup gear of the newly created clip to a new name, this disconnects it from the original. This how we copy a bunch of triggers for a new clip.
Steve
thanks 1 user thanked stevespaw for this useful post.
MichaelOlsen on 10/25/2020(UTC)
BarryF
#5 Posted : Friday, September 11, 2020 8:31:54 AM(UTC)
BarryF
Oh this little bit of Forum Wonder was a priceless find. Thank you... exactly what I wanted.
