rowby
#1 Posted : Wednesday, October 11, 2017 12:48:21 PM(UTC)
rowby
Hi all,
Is it possible to clone or copy an existing input?
I have a nice input set up and I'd rather not have to "start all over" when I want to create a slightly different version of the input.
Using Vmix 20
Thanks!
Rowby
stevespaw
#2 Posted : Wednesday, October 11, 2017 1:11:48 PM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
This is not immediately obvious, but I just create a virtual clip and then rename the new one.
This may be what you need.
Steve
sinc747
#3 Posted : Wednesday, October 11, 2017 1:22:56 PM(UTC)
sinc747
To expand on what Steve posted...
Rt click the settings icon on the Input you want to copy and select "Create Virtual Input." This works and make a "copy" of almost all inputs. I don't think is "copies" video files, but rather allows the new input to display what is playing in the original input.
Hope this helps.
- Tom
stevespaw
#4 Posted : Thursday, October 12, 2017 10:03:36 AM(UTC)
stevespaw
Thanks Tom,
Much better detail.
To add, the trick is to rename the new "virtual input" on the setup gear of the newly created clip to a new name, this disconnects it from the original. This how we copy a bunch of triggers for a new clip.
Steve
thanks 2 users thanked stevespaw for this useful post.
MichaelOlsen on 10/25/2020(UTC), TL68 on 2/27/2026(UTC)
BarryF
#5 Posted : Friday, September 11, 2020 8:31:54 AM(UTC)
BarryF
Oh this little bit of Forum Wonder was a priceless find. Thank you... exactly what I wanted.
TL68
#6 Posted : Friday, February 27, 2026 12:47:28 AM(UTC)
TL68
Sweden
Five years later this saved my day too!
