Feature Requests
Shortcut to toggle trigger on/off
Joined: 6/29/2016(UTC) Posts: 104 Location: Luxembourg
Thanks: 48 times Was thanked: 14 time(s) in 12 post(s)
Hey guys,
I've searched the forum because I couldn't believe this has not been asked before. I think it would be really great to have a shortcut function that can toggle on/off a trigger (by index) for a specific input.
For example using instant replay in sports I use a trigger that overlays off the scorebug by transition in of Replay A and a trigger that overlays the scorebug back on 2 seconds after the replay has finished.
Now in half time or during time outs I often combine replay highlights and show them again. Now I obviously don't want the scorebug to appear just after the highlights finish because we are still in a break and have a talent on air so I have to manually go into settings of Replay A and toggle the triggers off.
I can imagine plenty of scenarios where this shortcut could be handy and I would be happy if you put a +1 below this FR.
Marc
Rank:: Advanced Member
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Hi Marc
Guess so far no one has ever had an issue with it ever since triggers were available ;-)
More serious note. How would you know if they were on of off especially in the case of multiple triggers which one etc
Is there no way to have the title trigger on the transition in of your cameras and such ? if your ovl is already on it wouldn't change a thing but if not then it would avoid you forgetting it
Originally Posted by: doggy  How would you know if they were on of off especially in the case of multiple triggers which one etc
Haha , better to add activator to my FR as well then ;) Originally Posted by: doggy  Is there no way to have the title trigger on the transition in of your cameras and such ? if your ovl is already on it wouldn't change a thing but if not then it would avoid you forgetting it Well, no as at the end of the highlights clip during break I will transition in to the camera as well. I can even imagine using this shortcut function as a trigger in triggers. In my last productions I just caught myself (too) many times mouse clicking triggers on and off and I think it would be handy to automate further. Thanks for your valuable input Marc
Joined: 6/2/2020(UTC) Posts: 67   Location: Berlin Thanks: 8 times Was thanked: 9 time(s) in 8 post(s)
Hello mburell1980,
Isn’t virtual Inputs the way to go for your demand?
Virtual Inputs can be connected to triggers as well es trigger actions after completion. So in your Case you will end in two Replay Inputs, one with and one without the linked trigger.
This will alter your workflow in this manner that you will need more “SwitcherStyle Input Buttons” then a few Switcher buttons and a lot of modifier buttons.
I also think that a visual feedback of wich trigger is active is must for this operational method. This will require a ui change to make them visible. I could imagine a look like the aditional mixers or virtual sets wich are attached left to the input. Actual you would find yourself clicking the same triggers menu just for visual checking, even if you find solution to activate triggers remotly.
Greetings Paul
Feature Requests
