Hallo I have an HD license and i can't connect the output in gotomeeting. I have already followed Martin's guidance..
- In Settings select Performance - Enable Show Advanced Settings - Select the Output Format to be YUY2
but I'm still in trouble. all alternative options to the webcam do not work, the external 2 output displays the bars. does anyone have a solution for this? thanks!!
Just checking, did you turn External Output on and did the button turn red?
Yes! is on and turned red! but still nothing
... but i have found something strange, on skype works well but the image is mirrored
Same problem here. vMix works fine with other software such as Zoom and Teams, but not with GoToMeeting. Tried the YUY2 fix, but to no avail. How to troubleshoot?
Same problem here, too. External Video is not recognized by gotomeeting although setting is set to YUV2.
Has anyone figured out a fix for this? Still can't use vMix with GoToWebinar
Rank:: Newbie
Joined: 3/12/2013(UTC) Posts: 7   Location: London Thanks: 1 times
Having the same issue with Wowza! Stream health is good but no video!
Hi All - I have a presentation tonight on GoToWebinar and reading above looks like we can't get GTW to recognize Vmix as an external camera; is this still the case? No issues with Skype or Zoom. In fact been doing live TV (CNBC) through Vmix using Skype or Zoom, no issues at all. Thanks everyone and happy holidays. Todd.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Bit of a hack/workaround. Use NDI Virtual webcam app. Take Program from vMix as NDI source.
