3rd party compressor/limiter audio plugins for Vmix
Thanks: 30 times Was thanked: 1 time(s) in 1 post(s)
I want to get more control over the output audio in vmix for livestreaming my church services, as we can't rely on the audio technician to constantly keep an eye on the vmix audio signal. The inbuilt compressor is pretty straightforward, and I was wondering whether I can use VST or similar plugins within vmix.
From the vMix User Guide Quote:The Audio Plugins feature allows adding 3rd party audio plugins to inputs and outputs in vMix.
vMix supports all 64-bit VST3 audio plugins. VST3 is a popular audio plugin standard by Steinberg commonly used by DAW (Digital Audio Workstation) software.
 1 user thanked SportsNetUSA.net for this useful post.
Joined: 8/24/2017(UTC) Posts: 21 Location: Madrid, Spain
Thanks: 1 times Was thanked: 7 time(s) in 7 post(s)
Yes. We are currently using Waves 10 VST3 plugins in Vmix and it works perfectly.
 1 user thanked streammediaevent for this useful post.
Originally Posted by: streammediaevent  Yes. We are currently using Waves 10 VST3 plugins in Vmix and it works perfectly. That's great, thanks - does it give you access to the plugin's own UI, or does it give you a list of controls?
Joined: 5/13/2014(UTC) Posts: 520   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
Originally Posted by: grDancer  Originally Posted by: streammediaevent  Yes. We are currently using Waves 10 VST3 plugins in Vmix and it works perfectly. That's great, thanks - does it give you access to the plugin's own UI, or does it give you a list of controls? I use the Waves L2 Ultramaximizer and I get to see the GUI from the plug-in. The only downside with plugins like this is that their GUI opens as a "modal" window, so you can't leave it open whilst you use the rest of vMix. You have to open it up, adjust the settings, check it's sounding alright, and then close it again. Aside from that, VST plugins like this one work very well in vMix.
 1 user thanked zenvideo for this useful post.
 2.PNG (21kb) downloaded 1 time(s).Hi There, Wondering if you can help with L2 Ultramaximizer.... I have installed it via Waves Central 13.0.9 and gone to vMix and see attachment - Thew driver displays, but no Plugin comes up in the drop down list. Can any one please help? Cheers Gerry
