Fullscreen change setting from output to multiview
Rank:: Newbie
I want to change the setting from fullscreen from output to multiview. But that does not work. Also not at the settings output tab. I only can select the output option. Can anybody advise how to change this setting. When I press Fullscreen with the output active the output is shown on the second screen so that is not the problem. But i want to select multiview.
Thanks in advance
Joined: 12/27/2012(UTC) Posts: 5,462  Location: Belgium Thanks: 312 times Was thanked: 1009 time(s) in 831 post(s)
Rank:: Newbie
Many thanks for the quick reaction.
Yes I know. Bur when I click on multiview or any other option it does not change. I can not get the tickmark for Multiview. It stays at Output. Also in the settings when I select Multiview and close it. When I select the settingstabsheet again it still is on Output. There is no way I can change it. But output works. So the option fullscreen works but I want another option.
Rank:: Newbie
Found the solution. On the setting page the setting for Fullscreen and and output to NDI where both the same. they where both Multiview. As soon as I changed the NDI setting to Output it worked.
