Merwekade
#1 Posted : Monday, September 7, 2020 6:46:47 AM(UTC)
Merwekade
Netherlands
I want to change the setting from fullscreen from output to multiview. But that does not work. Also not at the settings output tab. I only can select the output option. Can anybody advise how to change this setting. When I press Fullscreen with the output active the output is shown on the second screen so that is not the problem. But i want to select multiview.
Thanks in advance
#2 Posted : Monday, September 7, 2020 7:11:02 AM(UTC)
Helpfiles -> fullscreen
Merwekade
#3 Posted : Monday, September 7, 2020 7:13:01 AM(UTC)
Merwekade
Netherlands
Many thanks for the quick reaction.
Yes I know. Bur when I click on multiview or any other option it does not change. I can not get the tickmark for Multiview. It stays at Output. Also in the settings when I select Multiview and close it. When I select the settingstabsheet again it still is on Output. There is no way I can change it. But output works. So the option fullscreen works but I want another option.
Merwekade
#4 Posted : Monday, September 7, 2020 7:27:26 AM(UTC)
Merwekade
Netherlands
Found the solution. On the setting page the setting for Fullscreen and and output to NDI where both the same. they where both Multiview. As soon as I changed the NDI setting to Output it worked.
