Video Delay longer than 2 min?
You have been a member since:: 2/15/2014(UTC) Posts: 1
Is it possible to get the video delay to be longer than 2 minutes? We are using vMix for BBall replay; Picture in Picture Overlay with Clock in lower left corner. The Officials said they would like to be able to review back at least 5 minutes.
An option would be to get a BMD recorder and send the output to that, then try to retrieve it for replay?
Thank You.
Lenovo W540 - (W7) Sonnet Echo Express SE II BMD Intensity Pro x 2 Plugable USB2 Display Adapter A couple of HDMI Cams and an HDMI TV
Joined: 8/3/2013(UTC) Posts: 48  Location: Florida Thanks: 19 times Was thanked: 1 time(s) in 1 post(s)
I have a similar need, I produce a 7 minute replay for horse competitions, it runs for up to 12 hours at a time with a perfect 7 minute delay or any delay of your choosing although it is a 2 system setup. I feed the delay usually right from a single camera but you could also feed it from a vmix output if you need a multi cam setup or the pip with the clock showing. I use a Magnavox DVD model MDR533 I believe. I feed a composite video in and composite or HDMI out . Sounds kinda crazy as I have prob $100,000 worth of gear and you can get this thing in the US from Walmart for about $225 but it is bulletproof. I use it between 50 to 100 hours per month. there are other models as well, they just have larger hard drives but mine has a 500gb drive.
