tsp1000
#1 Posted : Saturday, February 15, 2014 11:57:25 AM(UTC)
tsp1000
Is it possible to get the video delay to be longer than 2 minutes?
We are using vMix for BBall replay; Picture in Picture Overlay with Clock in lower left corner.
The Officials said they would like to be able to review back at least 5 minutes.
An option would be to get a BMD recorder and send the output to that, then try to retrieve it for replay?
Thank You.
Lenovo W540 - (W7)
Sonnet Echo Express SE II
BMD Intensity Pro x 2
Plugable USB2 Display Adapter
A couple of HDMI Cams and an HDMI TV
imagebotique
#2 Posted : Saturday, February 15, 2014 3:06:53 PM(UTC)
imagebotique
I have a similar need, I produce a 7 minute replay for horse competitions, it runs for up to 12 hours at a time with a perfect 7 minute delay or any delay of your choosing although it is a 2 system setup. I feed the delay usually right from a single camera but you could also feed it from a vmix output if you need a multi cam setup or the pip with the clock showing. I use a Magnavox DVD model MDR533 I believe. I feed a composite video in and composite or HDMI out . Sounds kinda crazy as I have prob $100,000 worth of gear and you can get this thing in the US from Walmart for about $225 but it is bulletproof. I use it between 50 to 100 hours per month. there are other models as well, they just have larger hard drives but mine has a 500gb drive.
