Rinsky
#1 Posted : Saturday, September 5, 2020 12:15:11 AM(UTC)
Rinsky
I am trying to Cut in Mix 2 to a specific Input via OnTransitionIn and Out triggers, but unfortunately it doesn't work.
It works with OnOverlayIn and Out, but not with the transition.
Am I doing something wrong or does anyone know a workaround for this?
dmwkr
#2 Posted : Saturday, September 5, 2020 12:42:22 AM(UTC)
dmwkr
I had been down this road . . . ;-)
From https://www.vmix.com/help23/Triggers.html :
"Note that in order to prevent loops, transition effects have no effect for OnTransitionIn or OnTransitionOut."
Workaround might be to start a script OnTransitionIn, that executes the Cut function.
thanks 1 user thanked dmwkr for this useful post.
Rinsky on 9/5/2020(UTC)
Rinsky
#3 Posted : Saturday, September 5, 2020 12:56:21 AM(UTC)
Rinsky
Sounds reasonable, but it shouldn't be a problem if we use another mix and not the main mix, am I right?
So, maybe there is a chance for Martin to enable it for other mixes.
ezitjahy
#4 Posted : Monday, September 7, 2020 3:49:06 PM(UTC)
ezitjahy
"Note that in order to prevent loops, transition effects Taco Bell Survey have no effect for OnTransitionIn or OnTransitionOut."
Thank you for posting something like this
Rinsky
#5 Posted : Monday, September 7, 2020 7:25:14 PM(UTC)
Rinsky
Could you please show me how such a script would look like?
dmwkr
#6 Posted : Monday, September 7, 2020 10:05:55 PM(UTC)
dmwkr
This would be:
Code:
Function=Cut&Mix=1&Input=3
Mix parameter: 0 is the regular Mix, 1 is Mix2, ...
Input parameter: Name or number of the input to Cut, here Input no. 3
Does that work for you?
And, as always, here the disclaimer for the main scripting references to look for, if you want to learn some things:
- doggy's Scripting for Dummies post https://forums.vmix.com/...86-Scripting-for-Dummies (Great for learning syntax and examples)
- vMix's Function Reference https://www.vmix.com/hel...utFunctionReference.html (Great for finding what functions are out there)
- Richard's Script Builder App https://forums.vmix.com/...r-App---Updated-02-24-20 (Great for creating basic scripts)
thanks 2 users thanked dmwkr for this useful post.
LucaL on 9/7/2020(UTC), Rinsky on 9/8/2020(UTC)
Rinsky
#7 Posted : Tuesday, September 8, 2020 1:06:48 AM(UTC)
Rinsky
Ohhh! Great! Know I understand...it's really that easy...
I was looking into the scripting stuff, but couldn't figure it out, because I was thinking the wrong way.
Thank you very much! Everything works just fine now.
