Trigger OnTransition Cut for Mix 2 doesn't work
Thanks: 39 times Was thanked: 39 time(s) in 35 post(s)
I am trying to Cut in Mix 2 to a specific Input via OnTransitionIn and Out triggers, but unfortunately it doesn't work.
It works with OnOverlayIn and Out, but not with the transition.
Am I doing something wrong or does anyone know a workaround for this?
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
I had been down this road . . . ;-) From https://www.vmix.com/help23/Triggers.html : "Note that in order to prevent loops, transition effects have no effect for OnTransitionIn or OnTransitionOut." Workaround might be to start a script OnTransitionIn, that executes the Cut function.
 1 user thanked dmwkr for this useful post.
Sounds reasonable, but it shouldn't be a problem if we use another mix and not the main mix, am I right?
So, maybe there is a chance for Martin to enable it for other mixes.
Originally Posted by: dmwkr  I had been down this road . . . ;-) From https://www.vmix.com/help23/Triggers.html : "Note that in order to prevent loops, transition effects Taco Bell Survey have no effect for OnTransitionIn or OnTransitionOut." Workaround might be to start a script OnTransitionIn, that executes the Cut function. Thank you for posting something like this
Originally Posted by: dmwkr  I had been down this road . . . ;-) From https://www.vmix.com/help23/Triggers.html : "Note that in order to prevent loops, transition effects have no effect for OnTransitionIn or OnTransitionOut." Workaround might be to start a script OnTransitionIn, that executes the Cut function. Could you please show me how such a script would look like?
 2 users thanked dmwkr for this useful post.
Ohhh! Great! Know I understand...it's really that easy...
I was looking into the scripting stuff, but couldn't figure it out, because I was thinking the wrong way.
Thank you very much! Everything works just fine now.
