Feature Requests
Several Countdown supported per title when using OnCountdownComplete
Joined: 7/31/2016(UTC) Posts: 69   Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
I will do my best to give you an example. Namely, I do something about handball, more about exclusion, so I have 3 variables that are excluded when they reach zero. So this is an example of a problem in vmix. Look. We have three variables Time1, Time2 and Time3. (I did that in GT Designer) Time1 is initially 10 sec, Time2 20 sec, Time3 30 sec. With a space I start the countdown to zero. When each reaches its zero, it should disappear one by one. I did this via the trigger option. However, the problem is that when the first Time1 reaches zero all the others are also deleted (OnCountdownComplete, Function = Title> SetTextVisibleOff) for all three but only when they reach zero. I hope I explained it well. look at the pictures First: Time1=10, Time2=20, Time3=30  vmix1problem.jpg (136kb) downloaded 0 time(s).Second: Press Space for countdown- Now is Time1=05, Time2=15,Time3=25  vmix2problem.jpg (136kb) downloaded 0 time(s).Now:  vmix3problem.jpg (139kb) downloaded 0 time(s).Look after this sec, all hide. Not only Time1 but Time2 and Time3  vmix4problem.jpg (137kb) downloaded 0 time(s).look Trigger in input proba.gtzip  vmix5problem.jpg (162kb) downloaded 1 time(s). vmix6problem.jpg (160kb) downloaded 0 time(s). vmix7problem.jpg (161kb) downloaded 2 time(s).I think it would be good to separate in some way in the trigger OnCountDownComplete for all Time1, Time2, Time3 not at once. I hope you understand and that I have described the problem well
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Until this is implemented
use a script where you can check and manipulate each individual textblock based on each individual countdown value
@ Hall3008
I think the issue is that the “OnCountdownCompleted” Trigger function is not able to distinguish which countdown is the “target” countdown to use and so the first “completed” timer will “Trigger” all “OnCountdownCompleted“ functions in the list.
An alternate solution to doggy’s check script (for those that do not have VMix 4K or Pro) is to set up individual countdown timers that each “Trigger” of their own accord.
Feature Requests
