cambysys
#1 Posted : Thursday, February 13, 2014 8:12:40 PM(UTC)
cambysys
I want to key text over live video.
As a test, I created a power point slide with a black background and a white font.
Into VMIX, I loaded a video file and the powerpoint. I set the powerpoint to key over the video.
The problem is that there is black around the white text.
I do not know how to load images into this forum so I have put the images on my blog here:
http://thomsoneu.blogspo...ownstream-key-issue.html
Assistance appreciated
Thanks in advance.
Frank
vmixsupport
#2 Posted : Thursday, February 13, 2014 9:02:24 PM(UTC)
vmixsupport
Rank: Staff
Groups: Registered, Administrators
Was thanked: 159 time(s) in 72 post(s)
Hi Frank,
If you want to add text over the top, it would be much easier for you to use the "title" input instead. Select the "text" tab to choose plain text or you can also take advantage of our Title Designer:
http://forums.vmix.com.a....aspx?g=posts&t=1250
Then use the overlay buttons to overlay this over your video.
cambysys
#3 Posted : Thursday, February 13, 2014 10:03:19 PM(UTC)
cambysys
vmixsupport wrote:
Hi Frank,
Thanks for the response.
I fired up the title designer.
It works and produces a nice clear result - Thanks.
Some observations:
1
White text is hard to see against the checkerboard background.
2
The text box drag handles are not obvious and hard to grab.
3
No grab to stretch horizontally when right justified.
4
If one sets the Text/alignment to Right then the cursor position gets mucked up.
To edit right justified text, Set to left justify. Click outside the text box. Then Click back inside it.
I added some pictures to the original blog post to show the result and the issues.
Is this to say that down stream keying PP does not work or is there a way to get my original approach to work. The advantage of PP is that before the event, I (or maybe a friend) can type in all the titles I need and during the event I can flick through them.
Kelvin
#4 Posted : Friday, February 14, 2014 12:21:10 PM(UTC)
Kelvin
Try using a green background instead of black. I've done some keying from PowerPoint and Excel using the screen capture feature and the text is fantastic.
cambysys
#5 Posted : Friday, February 14, 2014 6:37:15 PM(UTC)
cambysys
Ah. Yes. The green worked great. I then experimented and found that I could get the same good results with black.
The procedure I found to get chroma key to work with Black is below.
The green works more easily.
PP WITH GREEN BACKGROUND
1
Starting with all sliders fully to the left and all check boxes cleared.
2
Set the "Colour Key" check box (and note the aussie spelling)
Observe the Check Box colour square turns black and back on the VMIX output we get the PP slide green background and white text
3
Click the "Auto Chroma Key" button
Observe the sliders and things move and on the VMIX output we get the white text keyed correctly over the source footage.
PP WITH BLACK BACKGROUND:
1
2
Observe the Check Box colour square turns black and back on the VMIX output we get overlaid white text but with black fury edges.
3
Observe the sliders and things move and the chroma key output stops working.
4
Drag the Chroma Key Slider all the way to the left.
Wolla it works.
ceejay7777
#6 Posted : Saturday, February 15, 2014 3:13:27 AM(UTC)
ceejay7777
cambysys wrote:
2
Actually, that's the "English" spelling (as opposed to the funny way it's done in the American colonies!!!)
