Jaysometin
#1 Posted : Thursday, August 13, 2020 3:02:24 AM(UTC)
Jaysometin
Hi, pls i need to send a Live mix Audio from MacBook to the live streaming pc.
I have Vmix Desktop capture on my MacBook but I'm not receiving any Audio on vmix pc under NDI input.
Pls help.
Question 2.
How do i get good Audio level on my streaming platform ie.Faceebook/ Youtube, without Clipping on my Vmix Audio capture?.
dmwkr
#2 Posted : Thursday, August 13, 2020 6:20:48 AM(UTC)
dmwkr
Was thanked: 154 time(s) in 138 post(s)
thanks 2 users thanked dmwkr for this useful post.
Jaysometin on 8/13/2020(UTC), revjgc on 9/8/2020(UTC)
hellokitty
#3 Posted : Friday, August 28, 2020 2:57:11 AM(UTC)
hellokitty
Many ways to do it.
https://www.audinate.com/
JDroadie
#4 Posted : Friday, August 28, 2020 5:23:57 AM(UTC)
JDroadie
Question 2.
Try using the audio compressor on the master output. Its the the gear on the master in the audio mixer. 2-3:1 ratio Threshold -18 maybe -24,
Then in "general" add 6db of gain. basically you want to reduce some dynamic range so you can make the average level louder.
Some VST plugin compressors may do this better.
thanks 1 user thanked JDroadie for this useful post.
revjgc
#5 Posted : Tuesday, September 8, 2020 3:04:29 AM(UTC)
revjgc
Originally Posted by: dmwkr Go to Quoted Post
https://www.vmix.com/knowledgebase/article.aspx/86/sending-system-audio-from-a-mac-system-running-vmix-desktop-capture-for-ndi
To make it easier for future people to find the help, this is what that page says:
In order to send the system audio from a Mac system running vMix Desktop Capture for NDI (that is the audio of any programs such as web browsers video players etc), a 3rd party audio driver needs to be installed from the below web site:
https://github.com/matti...lower/releases/tag/2.0b2
Once installed the Soundflower driver will need to be selected as both the Sound Output and Sound Input devices in OSX Sound Preferences.
The output will route all of the systems audio to Soundflower and the Input will be used by vMix Desktop Capture to send the audio.
vMix staff should really add this to the relevant page on Desktop Capture.
thanks 1 user thanked revjgc for this useful post.
tatamata on 12/26/2020(UTC)
3579865
#6 Posted : Tuesday, December 15, 2020 4:25:17 AM(UTC)
3579865
If Soundflower doesn't work, BlackHole may be another option.
https://github.com/ExistentialAudio/BlackHole
thanks 1 user thanked 3579865 for this useful post.
Similar Topics
Problem with audio over ndi input. Vmix 18 + VLC MP (NDI)
by Hrynio 4/20/2017 5:17:56 AM(UTC)
