HighViewSport
#1 Posted : Thursday, February 13, 2014 2:36:20 AM(UTC)
HighViewSport
Hi Martin,
I recently installed vMix 12.0.0.71
My normal work flow for clients soccer games is:
Connect camera
Set recording to Deck link MJPEG Compressor, AVI, 1920 x 1080 saving to a fast internal drive.
Capture input from camera
Record both half's of game.
I then import both half's into Adobe Premier CS6 to edit full game and highlights for my client and club.
This time however I get very bad stuttering when playing back in CS6 which is not normal. Try create new files again with vmix and import.
Same result. Bad stuttering and very poor playback in CS6. Bummer, I cant edit highlights clip for my client.
Try option two:
Play game back from camera recording into Black Magic media express. Create two files for each half. Setting was AVI motion JPEG 1080
Now import those media express recording into premier CS6. Works perfectly. No stuttering what so ever. Managed to compile my highlights package and is now uploading to YouTube.
Very happy to complete but wonder what the issue is with vMix recordings?
The only change in my system was upgrading to vmix 12. Any thoughts please?
Cheers
Bryan
#2 Posted : Thursday, February 13, 2014 2:52:09 AM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
Could you provide a copy of the recording log file for review?
HighViewSport
#3 Posted : Thursday, February 13, 2014 2:57:47 AM(UTC)
HighViewSport
Yup can do Martin but how do I do that. vMix was closed?
#4 Posted : Thursday, February 13, 2014 4:12:18 AM(UTC)
The log file is in the same directory as the recording with the same filename.
HighViewSport
#5 Posted : Thursday, February 13, 2014 4:18:46 AM(UTC)
HighViewSport
This is first half:
2/10/2014 7:52:31 AM, Version: 12.0.0.58 x64
2/10/2014 7:52:31 AM, Size: 1920x1080
2/10/2014 7:52:31 AM, System: PAL 50i or 25p
2/10/2014 7:52:31 AM, Codec: Decklink MJPEG Compressor
2/10/2014 7:52:31 AM, Format: UYVY 16 1498831189
2/10/2014 7:52:31 AM, AudioDevice: vMix Audio - System Mix
2/10/2014 7:52:31 AM, AudioFormat: 44100 Hz 16 Bit 2 Channels
2/10/2014 7:52:31 AM, AudioDelay: 0
2/10/2014 7:52:31 AM, RestartInterval: 0
2/10/2014 7:52:31 AM, BitRate: 75
2/10/2014 8:13:08 AM, StartRecording
2/10/2014 9:04:36 AM, StopRecording
2/10/2014 9:04:36 AM, Duration: 00:51:28
2/10/2014 9:04:36 AM, Frames: 77212
2/10/2014 9:04:36 AM, DroppedFrames: 0
2/10/2014 9:04:36 AM, DueToSourceFrameRate: 0
2/10/2014 9:04:36 AM, DueToHardDiskOrCPU: 0
2/10/2014 9:04:36 AM, DroppedSamples: 0
2/10/2014 9:04:36 AM, MissedSamples: 0
2/10/2014 9:04:36 AM, SyncedSamples: 0
2/10/2014 9:04:36 AM, AudioOffset: 40
2/10/2014 9:04:36 AM, AudioDelay: 0
2/10/2014 9:04:36 AM, AudioEngine
2/10/2014 9:04:36 AM, Running: True
2/10/2014 9:04:36 AM, SampleRate: 48000hz 16 Bit
2/10/2014 9:04:36 AM, MixingErrors: 0
2/10/2014 9:04:36 AM, Streams
2/10/2014 9:04:36 AM, Stream0
2/10/2014 9:04:36 AM, Samples: 218670
2/10/2014 9:04:36 AM, Dropped: 0
2/10/2014 9:04:36 AM, Latency: 2
2/10/2014 9:04:36 AM, Stream1
2/10/2014 9:04:36 AM, Samples: 50
2/10/2014 9:04:36 AM, Latency: 50
2/10/2014 9:04:36 AM, Stream2
2/10/2014 9:04:36 AM, Samples: 0
2/10/2014 9:04:36 AM, Latency: 0
2/10/2014 9:04:36 AM, AudioInputs
2/10/2014 9:04:36 AM, Decklink Video Capture (3)
2/10/2014 9:04:36 AM, Latency: 90/80
2/10/2014 9:04:36 AM, Resampled: 0 ms
Second Half:
2/10/2014 9:11:42 AM, StartRecording
2/10/2014 10:03:28 AM, StopRecording
2/10/2014 10:03:28 AM, Duration: 00:51:46
2/10/2014 10:03:28 AM, Frames: 77660
2/10/2014 10:03:28 AM, DroppedFrames: 0
2/10/2014 10:03:28 AM, DueToSourceFrameRate: 0
2/10/2014 10:03:28 AM, DueToHardDiskOrCPU: 0
2/10/2014 10:03:28 AM, DroppedSamples: 0
2/10/2014 10:03:28 AM, MissedSamples: 0
2/10/2014 10:03:28 AM, SyncedSamples: 0
2/10/2014 10:03:28 AM, AudioOffset: 20
2/10/2014 10:03:28 AM, AudioDelay: 0
2/10/2014 10:03:28 AM, AudioEngine
2/10/2014 10:03:28 AM, Running: True
2/10/2014 10:03:28 AM, SampleRate: 48000hz 16 Bit
2/10/2014 10:03:28 AM, MixingErrors: 0
2/10/2014 10:03:28 AM, Streams
2/10/2014 10:03:28 AM, Stream0
2/10/2014 10:03:28 AM, Samples: 395262
2/10/2014 10:03:28 AM, Dropped: 0
2/10/2014 10:03:28 AM, Latency: 2
2/10/2014 10:03:28 AM, Stream1
2/10/2014 10:03:28 AM, Samples: 50
2/10/2014 10:03:28 AM, Latency: 50
2/10/2014 10:03:28 AM, Stream2
2/10/2014 10:03:28 AM, Samples: 0
2/10/2014 10:03:28 AM, Latency: 0
2/10/2014 10:03:28 AM, AudioInputs
2/10/2014 10:03:28 AM, Decklink Video Capture (3)
2/10/2014 10:03:28 AM, Latency: 20/80
2/10/2014 10:03:28 AM, Resampled: 0 ms
#6 Posted : Thursday, February 13, 2014 4:23:18 AM(UTC)
Thanks, the audio device should be set to "vMix Audio".
The system mix option should not normally be used.
Out of curiosity, does the recording play ok in media player or vMix directly?
HighViewSport
#7 Posted : Thursday, February 13, 2014 4:30:58 AM(UTC)
HighViewSport
Thanks for the settings tip :)
Yes, that's the strange thing about all this. The files play back ok in vlc and just tested inside vmix and yes plays back ok too.
Hmmm very strange?
#8 Posted : Thursday, February 13, 2014 4:45:43 AM(UTC)
The only thing I can think of is Premiere may not like the audio format of the system mix device (44100)
The previous recordings may have used vMix Audio which defaults to 48000. If you have the log files from older
recordings that are ok, you can check them to see if this is the case.
PFBM
#9 Posted : Thursday, February 13, 2014 6:03:59 PM(UTC)
PFBM
use Cineform HD codec .
It´s FREE !!
Has very good quality and premiere likes it :)
also, 48k is the standard audio for video.
http://gopro.com/softwar...pro-studio-edit-software
Cheers,
PFBM
