ardale0508
#1 Posted : Friday, August 28, 2020 1:10:01 AM(UTC)
ardale0508
I got a scenario.
If a client wants to send me their own custom made title(s) to use for a production, what file format does it need to be in? I imagine it would be a png file if I'm not wrong? What if it has an animation?
Thank you!
#2 Posted : Friday, August 28, 2020 1:55:07 AM(UTC)
static title yes as image is possible ( into a GT title)
with animation , probably best as a video and convert to an image sequence (or if they can send that even better) and put that in a GT title or as a image sequence input
all depends if text needs to be added/changed during production
Best imo is make the title based on the design partially images, partially GT graphics and text fields
ardale0508
#3 Posted : Friday, August 28, 2020 3:07:52 AM(UTC)
ardale0508
Gotcha. I mean, I could technically import a .png file and size it up and assign it to an overlay, correct? For a static image..
But if they created an animation, they would have to save the file as a xml? I just want to clarify. Thanks again!
#4 Posted : Friday, August 28, 2020 4:36:14 AM(UTC)
this is a very bad scenario imho (unless you want troubles)
ask your clients graphics elements like logos, presentation graphic charter including fonts, colors, etc... and create all the visuals yourself
#5 Posted : Friday, August 28, 2020 5:33:49 AM(UTC)
Yes upsizing an image will look good NOT !
why would you have to save as a xml file? check out some of the vMix videos regarding image sequenses
Similar Topics
Issue with custom lower third (General Discussion)
by ChrisDE 7/15/2017 8:49:32 AM(UTC)
