Thanks: 4 times Was thanked: 20 time(s) in 19 post(s)
this is a total novice question but does anyone know how i get this PTZ Zoom working on whatever is in the vMix output window ?
API.Function("PTZZoomIn",Input:="Video1")
when i have "Video1" it works but if i change it to Input:="Active" it doesnt do anything ? I thought the output window was called "Active" but i also tried "Output" and still nothing ?? I also tried Input:="Preview" to see if it worked in the preview window but no luck there either... not sure where im going wrong ??
appreciate any help..
Joined: 12/27/2012(UTC) Views messages in topic : 5,533  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
in your script check which (PTZ)camera is active and put that as your input in the function
i dont want the PTZ to only work on one Input source though i want it to work with whatever Input is in the output window..
if i use this web command instead... Function=PTZZoomIn then it will always zoom the Preview window no matter which Input is displayed.. but i cant get it to work for the output..
if i use Function=PTZZoomIn&Input=Active it does nothing ??
Originally Posted by: mtone  i dont want the PTZ to only work on one Input source though i want it to work with whatever Input is in the Active window..
an input has to be connected as a (Virtual) PTZ first n order to even respond to a PTZ command a good idea is to check if it actually works as a shortcut first (thye are the same functions anyway) and why not use a regular zoom command?
it works fine as regular shortcut.. I have zoom in and zoom out mapped to two joystick buttons on the output window and any inputs that are showing in the output window zoom perfectly when i press those buttons..
do you see any problem with this command ?
API.Function("PTZZoomIn",Input:="Active")
Are you allowed to specify "Active" as the input to send the function to the main output window ?
where is the speed value ? ( check what is needed when you create it as a shortcut)
the speed value doesnt matter.. if you leave it out it uses the default setting.. but i have put it in also and it makes no difference..
when i use this command it zooms "Video1" whether it is in the preview or output windows (like you would expect) API.Function("PTZZoomIn",Input:="Video1")
when i use this to try and specify only zoom for the output window it does nothing.. API.Function("PTZZoomIn",Input:="Active")
If i use this to try and specify zoom for the preview window it also does nothing.. API.Function("PTZZoomIn",Input:="Preview")
however when i use this command it will zoom whatever is showing in preview window. Function=PTZZoomIn
But then if i use this to try and specify zoom for the output window it again does nothing.. Function=PTZZoomIn&Input=Active
so when i set the command... Function=PTZZoomIn
it works exactly how i would like but its in the preview window whereas i want the zoom to work exclusively on the output window..
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
 1 user thanked dmwkr for this useful post.
Originally Posted by: dmwkr  Awesome, that works! thank you.. i had been getting nowhere for hours. I actually skimmed over that page of the user guide a week or two ago but totally missed the 0 and -1 settings. so thanks for letting me know... :)
