mtone
#1 Posted : Tuesday, August 25, 2020 1:55:28 AM(UTC)
mtone
this is a total novice question but does anyone know how i get this PTZ Zoom working on whatever is in the vMix output window ?
API.Function("PTZZoomIn",Input:="Video1")
when i have "Video1" it works but if i change it to Input:="Active" it doesnt do anything ? I thought the output window was called "Active" but i also tried "Output" and still nothing ?? I also tried Input:="Preview" to see if it worked in the preview window but no luck there either... not sure where im going wrong ??
appreciate any help..
#2 Posted : Tuesday, August 25, 2020 2:04:04 AM(UTC)
in your script check which (PTZ)camera is active and put that as your input in the function
mtone
#3 Posted : Tuesday, August 25, 2020 2:44:58 AM(UTC)
mtone
i dont want the PTZ to only work on one Input source though i want it to work with whatever Input is in the output window..
if i use this web command instead... Function=PTZZoomIn then it will always zoom the Preview window no matter which Input is displayed.. but i cant get it to work for the output..
if i use Function=PTZZoomIn&Input=Active it does nothing ??
#4 Posted : Tuesday, August 25, 2020 3:03:08 AM(UTC)
Originally Posted by: mtone Go to Quoted Post
i dont want the PTZ to only work on one Input source though i want it to work with whatever Input is in the Active window..
an input has to be connected as a (Virtual) PTZ first n order to even respond to a PTZ command
a good idea is to check if it actually works as a shortcut first (thye are the same functions anyway)
and why not use a regular zoom command?
mtone
#5 Posted : Tuesday, August 25, 2020 3:30:03 AM(UTC)
mtone
it works fine as regular shortcut.. I have zoom in and zoom out mapped to two joystick buttons on the output window and any inputs that are showing in the output window zoom perfectly when i press those buttons..
do you see any problem with this command ?
API.Function("PTZZoomIn",Input:="Active")
Are you allowed to specify "Active" as the input to send the function to the main output window ?
#6 Posted : Tuesday, August 25, 2020 3:40:48 AM(UTC)
where is the speed value ? ( check what is needed when you create it as a shortcut)
mtone
#7 Posted : Tuesday, August 25, 2020 12:59:37 PM(UTC)
mtone
the speed value doesnt matter.. if you leave it out it uses the default setting.. but i have put it in also and it makes no difference..
when i use this command it zooms "Video1" whether it is in the preview or output windows (like you would expect)
when i use this to try and specify only zoom for the output window it does nothing..
If i use this to try and specify zoom for the preview window it also does nothing..
API.Function("PTZZoomIn",Input:="Preview")
however when i use this command it will zoom whatever is showing in preview window.
Function=PTZZoomIn
But then if i use this to try and specify zoom for the output window it again does nothing..
so when i set the command... Function=PTZZoomIn
it works exactly how i would like but its in the preview window whereas i want the zoom to work exclusively on the output window..
dmwkr
#8 Posted : Tuesday, August 25, 2020 3:16:20 PM(UTC)
dmwkr
Was thanked: 153 time(s) in 137 post(s)
Does it work if you use 0 for preview and -1 for active?
https://www.vmix.com/help23/DeveloperAPI.html
thanks 1 user thanked dmwkr for this useful post.
mtone on 8/25/2020(UTC)
mtone
#9 Posted : Tuesday, August 25, 2020 4:52:19 PM(UTC)
mtone
Awesome, that works! thank you.. i had been getting nowhere for hours.
I actually skimmed over that page of the user guide a week or two ago but totally missed the 0 and -1 settings. so thanks for letting me know... :)
Similar Topics
Goal Scripting question (General Discussion)
by Salleman 3/21/2023 10:01:15 PM(UTC)
Quick Scripting Question (General Discussion)
by gmillward 4/1/2021 5:55:14 AM(UTC)
Vmix Call Scripting Question (vMix Call)
by Chris Daum 2/10/2021 7:52:36 PM(UTC)
Very Easy Scripting Question - Text removal! (3rd Party Software and Development)
by mcook75 12/9/2020 8:19:43 PM(UTC)
vMix'AMCP Scripting Question (General Discussion)
by TFMG 6/22/2018 7:53:45 AM(UTC)
PTZ scripting question (General Discussion)
by julianlee 3/10/2017 6:42:45 AM(UTC)
