coolboy18
#1 Posted : Tuesday, August 25, 2020 5:19:34 AM(UTC)
coolboy18
i have a very simple question. I am currently looking for a way to use your HDMI source in vMix. I came across the Elgato HD60 which can 1080p with 60fps which is completely sufficient for my purposes.
unfortunately I could not find out whether the Elgato HD60 is supported by vMix.
SportsNetUSA.net
#2 Posted : Tuesday, August 25, 2020 6:28:03 AM(UTC)
SportsNetUSA.net
vMix only supports
Elgato 4K 60 PRO Mk. 2
Elgato HD 60 S +
Elgato Cam Link (Progressive Video Sources Only)
The above 3 are plug and play, meaning they will work out of the box with vMix.
Only the below two capture devices require a special driver to be installed in order to use with vMix:
Game Capture HD60S
Game Capture HD60 Pro
https://www.vmix.com/knowledgeba...apture-devices-with-vmix
The Elgato HD60 was not a vMix supported device.
coolboy18
#3 Posted : Tuesday, August 25, 2020 4:40:31 PM(UTC)
coolboy18
I have already found the question in the forum that it probably does not work if another Capute Card is on the PC. Apparently it should work but I don't want to buy anything if it doesn't work.
https://forums.vmix.com/...-in-the-VMix-Camera-List
Simsyuk
#4 Posted : Friday, August 28, 2020 8:55:03 PM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
I'm using a HD60 via vmix without any issues. I just downloaded the latest drives from Elgato Elgato HD60 Drivers and it worked, the only issue I've found is it's not instant capture, in other words it's about 1 second delay.
