bar807
#1 Posted : Monday, August 24, 2020 3:16:49 PM(UTC)
bar807
I designed a title with transitions/effects/reveal/etc on Laptop #1 and when I input on vMix from that laptop the title works perfectly. I then save the title on dropbox to access it from laptop #2, load it into vMix on laptop #2 and it works like a flat image when, no reveals and effects. I load it on GT Title Designer on laptop #2 and it works normal. Tried saving it again on laptop #2 but same issue when I load it on vMix. Any clue?
Peter1000
#2 Posted : Monday, August 24, 2020 8:00:08 PM(UTC)
Peter1000
Switzerland
Was thanked: 84 time(s) in 64 post(s)
maybe you don‘t have the same version on the second laptop?
only 4k and pro versions are supporting animations. the lower versions will show the title, but no the animation.
bar807
#3 Posted : Tuesday, August 25, 2020 12:16:19 AM(UTC)
bar807
On the 1st Laptop (which is where it works fine) I'm using the trial, so that is fully functional, on the other laptop, I have the HD version. But the titles that come with the software work fine with the animations. Its the one that are user created that will not work?
#4 Posted : Tuesday, August 25, 2020 12:49:29 AM(UTC)
from the help files !
Playing Animations
Animations are supported in the 4K and Pro editions of vMix only.
The exception is the included built in GT templates provided with vMix which will work in all editions.
