info@streamia.gr
#1 Posted : Monday, August 24, 2020 6:36:26 AM(UTC)
info@streamia.gr
Greece
Testing vmix I cannot crop multiview overlay which includes another overlay but I can zoom and move it around.
Because it is difficult for me to describe it effectively, I prepared this video for you:
Thank you in advance.
Panagiotis Sidiropoulos
Vince Beck
#2 Posted : Monday, August 24, 2020 11:50:45 AM(UTC)
Vince Beck
That’s a limitation on sub inputs. The workaround I use is to put that input in a mix input as program then use that input as overlay and it will allow crop. The other option is to use virtual sets.
#3 Posted : Monday, August 24, 2020 9:38:14 PM(UTC)
@ info@streamia.gr
The MultiView Input "crop" on overlays only crops the "main" layer of the Input used.
If the if the Input used is also a MultiView Input, then any of the Overlays of that Input will need to be "cropped" individually within the original Input (or a Virtual Copy of it) as those layers cannot be accessed from the other MultiView.
The Mix Input method will work because it essentially processes (renders) the Input as a single Image without layers.
jonnybuttons
#4 Posted : Saturday, December 17, 2022 6:55:31 AM(UTC)
jonnybuttons
Has there been any solution to this?
Experiencing this same problem 2 years later....
Why don't the overlays/layers just CROP?!???
