Crop on ninput as overlay is not working
Joined: 8/24/2020(UTC) Posts: 1  Location: Athens, Greece
Testing vmix I cannot crop multiview overlay which includes another overlay but I can zoom and move it around. Because it is difficult for me to describe it effectively, I prepared this video for you: Thank you in advance. Regards, Panagiotis Sidiropoulos
Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
That’s a limitation on sub inputs. The workaround I use is to put that input in a mix input as program then use that input as overlay and it will allow crop. The other option is to use virtual sets.
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ info@streamia.grThe MultiView Input "crop" on overlays only crops the "main" layer of the Input used. If the if the Input used is also a MultiView Input, then any of the Overlays of that Input will need to be "cropped" individually within the original Input (or a Virtual Copy of it) as those layers cannot be accessed from the other MultiView. The Mix Input method will work because it essentially processes (renders) the Input as a single Image without layers. Ice
Joined: 12/17/2022(UTC) Posts: 3  Location: CA Thanks: 1 times
Has there been any solution to this?
Experiencing this same problem 2 years later....
Why don't the overlays/layers just CROP?!???
