sparkyjcm
#1 Posted : Thursday, August 20, 2020 11:57:22 PM(UTC)
sparkyjcm
I'm having audio drops while livestreaming in vmix since the last update. I'm hearing others have had the same issue. I get level indicators on audio interface, soundboard, interface driver software, but nothing in vmix. I have to exit out of vmix and restart it to fix. Is there a way I can go back to the previous release before this latest update?
dmwkr
#2 Posted : Friday, August 21, 2020 2:28:26 AM(UTC)
dmwkr
The .exe installation files are usually saved to the Document folder of your Windows user.
sparkyjcm
#3 Posted : Sunday, August 23, 2020 5:34:53 AM(UTC)
sparkyjcm
Thank you. I found 23.0.0.59 exe in the document folder and installed it. Hopefully this will stop the issues!
