Audio drops in latest version
Joined: 6/25/2020(UTC) Posts: 13  Was thanked: 1 time(s) in 1 post(s)
I'm having audio drops while livestreaming in vmix since the last update. I'm hearing others have had the same issue. I get level indicators on audio interface, soundboard, interface driver software, but nothing in vmix. I have to exit out of vmix and restart it to fix. Is there a way I can go back to the previous release before this latest update?
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
The .exe installation files are usually saved to the Document folder of your Windows user.
Thank you. I found 23.0.0.59 exe in the document folder and installed it. Hopefully this will stop the issues!
