ARSP
#1 Posted : Wednesday, August 19, 2020 10:57:04 AM(UTC)
ARSP
Brazil
I am needing to output 6 channels of audio embedded on the Decklink Duo 2 SDI.
I have one SDI source with 6 audios being fed to the Decklink input but
just two audios have shown on the output.
I just could get 2 audio output.
Anyone doing this ? I have tried several different setups.
Peter1000
#2 Posted : Wednesday, August 19, 2020 4:39:46 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
You can use these documents. It is the same principle as described, just without SRT in between.
You need the audio groups MAB
http://tvcrew.ch/wiki/do...sound_channels_with_vmix
thanks 1 user thanked Peter1000 for this useful post.
ARSP on 8/25/2020(UTC)
adamjohns
#3 Posted : Saturday, August 22, 2020 1:17:04 AM(UTC)
adamjohns
It is likely that you only have "Master" selected for the audio output. If you need more than two channels you will have to choose one of the other options such as "MA" or "MAB". the later being six channels of audio output.
