Hardware Compatibility
Decklink Duo 2 Embedded Audio Output
Joined: 8/12/2020(UTC) Posts: 1  Location: SAO PAULO Thanks: 1 times
I am needing to output 6 channels of audio embedded on the Decklink Duo 2 SDI. I have one SDI source with 6 audios being fed to the Decklink input but just two audios have shown on the output. I just could get 2 audio output. Anyone doing this ? I have tried several different setups.
Joined: 1/25/2019(UTC) Posts: 332  Thanks: 24 times Was thanked: 85 time(s) in 65 post(s)
 1 user thanked Peter1000 for this useful post.
Joined: 5/24/2020(UTC) Posts: 14   Location: Florida Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
It is likely that you only have "Master" selected for the audio output. If you need more than two channels you will have to choose one of the other options such as "MA" or "MAB". the later being six channels of audio output.
