Nixriq
#1 Posted : Wednesday, August 19, 2020 10:33:47 PM(UTC)
Nixriq
Hi guys,
I'm new here. I am having trouble getting Audio in my vmix Facebook and Youtube live streams. I have a Panasonic G85 camera with an external Mic attached to it and I am using the Avermedia ExtremeCap UVC - BU110 capture card on a Windows 10 PC. I can get the audio from the PC output so I know the mic is working and the master input shows a strong signal from the Capture card. What else can I check ?
Thanks.
#2 Posted : Thursday, August 20, 2020 1:53:15 PM(UTC)
@ Nixriq
Can you verify that you are sending Master Audio to your streams and not another audio bus?
Nixriq
#3 Posted : Friday, August 21, 2020 2:24:40 AM(UTC)
Nixriq
Hi guys,
I found out what was wrong. I had the windows default audio setting as the Audio source on my camera instead of the capture card. Fixing this resolved this issue. I have a mic attached plugged into the camera and that is making my video off sync with the audio, I just added an 80ms delay as suggested in the Audio Tutorial and I will see if that fixes the sync issue.
Thanks.
Soapm
#4 Posted : Friday, August 21, 2020 10:17:12 AM(UTC)
Soapm
Originally Posted by: Nixriq Go to Quoted Post
Hi guys,
Thanks.
Good luck, I wished there was an easy way to sync the audio. I've been trying for two months now and know there must be a better way.
mavik
#5 Posted : Friday, August 21, 2020 4:17:24 PM(UTC)
mavik
Point your cam onto this video
and record on your system.
Watching the recording framewise you then can "read" what delay you have.
Soapm on 8/24/2020(UTC)
Soapm
#6 Posted : Monday, August 24, 2020 8:22:57 AM(UTC)
Soapm
I guess I'm going to have to do this on my phone or tablet, I had it playing on the actual PC we use for vmix but because it's in the sound room, the camera doesn't point there. It's taken me this long to realize I need to try this another way.
Guest (4)
