No Audio from Vmix Facebook and Youtube live stream
Hi guys,
I'm new here. I am having trouble getting Audio in my vmix Facebook and Youtube live streams. I have a Panasonic G85 camera with an external Mic attached to it and I am using the Avermedia ExtremeCap UVC - BU110 capture card on a Windows 10 PC. I can get the audio from the PC output so I know the mic is working and the master input shows a strong signal from the Capture card. What else can I check ?
Thanks.
@ Nixriq
Can you verify that you are sending Master Audio to your streams and not another audio bus?
Hi guys,
I found out what was wrong. I had the windows default audio setting as the Audio source on my camera instead of the capture card. Fixing this resolved this issue. I have a mic attached plugged into the camera and that is making my video off sync with the audio, I just added an 80ms delay as suggested in the Audio Tutorial and I will see if that fixes the sync issue.
Thanks.
Thanks. Good luck, I wished there was an easy way to sync the audio. I've been trying for two months now and know there must be a better way.
Joined: 4/23/2017(UTC) Posts: 1,495  Location: Germany Thanks: 3 times Was thanked: 199 time(s) in 179 post(s)
Point your cam onto this video and record on your system. Watching the recording framewise you then can "read" what delay you have.
 1 user thanked mavik for this useful post.
Originally Posted by: mavik  Point your cam onto this video and record on your system. Watching the recording framewise you then can "read" what delay you have. I guess I'm going to have to do this on my phone or tablet, I had it playing on the actual PC we use for vmix but because it's in the sound room, the camera doesn't point there. It's taken me this long to realize I need to try this another way. Thanks
