reezyfasheezy
#1 Posted : Sunday, July 19, 2020 12:46:27 PM(UTC)
reezyfasheezy
I will preface my post by saying I am a video and vMix noob, so bear with me..
I have just purchased an HP Omen 17 laptop: i7-10750H 2.6ghz, 16 gb ram, RTX 2060, running trial version of vMix 23.0.0.59. I am attempting to connect a 2013 MacBook pro 2.4ghz i5, 4 gb Ram, intel iris graphics, and a Lenovo t430 i5-3320M 2.6ghz, 6gb ram, intel graphics 4000. I have a netgear gigabit switch GS108, with cat5e cabling to all computers. I am running the NDI tools scan converter on both MacBook and Lenovo. These computers are being captured using the NDI/Desktop capture input within vMix.
My current vMix settings are 1280x720, 59.94, although I have tried 1920x1080 at 30 and 59, still the same results. What I am experiencing is very choppy video playback, off of both computers, along with massive dropped frames in the statistics window. I have checked ethernet speeds on all computers, and they all say they are connected at 1gb. Any idea on what could be going on? I have gone through the vMix optimization check list and have made sure everything is good.
Gunnar Hauth
#2 Posted : Wednesday, August 19, 2020 7:47:52 AM(UTC)
Gunnar Hauth
Iceland
Did you ever get to the bottom of your problem?
I am having the same issue.
Kind regads
Gunnar
mavik
#3 Posted : Wednesday, August 19, 2020 6:08:00 PM(UTC)
mavik
test on the same computer with studio monitor. If that feed is good it the connection between then. So most likely your switch.
reezyfasheezy
#4 Posted : Thursday, August 20, 2020 11:05:30 AM(UTC)
reezyfasheezy
Thank you for your reply mavik. Upon further testing I realized that both my vMix pc and Lenovo were set for “public” internet profiles. Once i changed them to “private” it looked like the problem was fixed. Unfortunately I couldn’t figure out how to get the MacBook to work correctly.
mavik
#5 Posted : Thursday, August 20, 2020 11:37:08 PM(UTC)
mavik
Thanks for the feedback, glad you could fix it.
dmwkr
#6 Posted : Friday, August 21, 2020 2:25:19 AM(UTC)
dmwkr
Have you deactivated WiFi on your Macbook, just to make sure it's using the ethernet connection?
