Liberty Baptist Church
#1 Posted : Wednesday, August 19, 2020 10:13:34 AM(UTC)
We've been using 4 older Sony BRC-300 PTZ cameras with no issues. PC took a lightening hit and now I need to re-enter encoder settings. Our previous settings gave us a 4:3 resolution with a black bar left and right which is exactly what these cameras output. I cannot remember what settings we had for those PTZ's. Any wide screen setting gives us a stretched video that is very unflattering to the folks on camera. Would I be looking at 720x480 or something else?
SportsNetUSA.net
#2 Posted : Thursday, August 20, 2020 4:03:28 AM(UTC)
SportsNetUSA.net
640x480 is a 4:3 resolution, so would 800x600. Try those two first. You can always take a look at 720x480 as your setting, but it isn't a 4:3 resolution. If 720x480 gives your screen shots the format look of what you previously had, then use it.
The Sony BRC-300 is suppose to be capable of both 4:3, and 16:9 modes.
#3 Posted : Friday, August 21, 2020 12:11:32 AM(UTC)
Thanks for responding. Yes, the BRC-300 can do both 4:3 and 16:9 but the Roland VR-3 mixer/switcher we are using only outputs 4:3. I will try 640x480 and 800x600 and see if that works for us.
#4 Posted: : Sunday, August 23, 2020 9:14:19 AM(UTC)
I did a test steam using 640x480. Looks like that is the answer. Thanks. One day we will be able to upgrade to SDI or HD.
SportsNetUSA.net
#5 Posted : Sunday, August 23, 2020 4:54:34 PM(UTC)
SportsNetUSA.net
Good to see you found a setting that works. Having used the Roland VR-3 in the past, I know 720x480 is the preferred resolution for that unit. Did you give that resolution a try?
#6 Posted : Wednesday, August 26, 2020 8:14:25 AM(UTC)
No, I did not try 720x480 but I will. Thank You!
