xun
#1 Posted : Monday, August 17, 2020 8:42:24 PM(UTC)
xun
Germany
Hello @All,
how i can start a ticker from beginning if it triggers in and how i can transition the title out if the ticker is on the end of the text?
Or, how i can build a equal title what do this?
THX!
JimJim
XUN
#2 Posted : Monday, August 17, 2020 9:46:16 PM(UTC)
The hard part:
have it's inputs set as "Automatically restart with stransition "
The easy part:
Have a trigger on overlaying in that calls a script that checks how long its content is , relate that to the speed of the ticker taking into account the width of the ticker frame itself and the fontsize character width used plus the time it takes for the last character to travel the whole width of the ticker to calculate the total time needed before transitioning out .
or take a stopwatch , time how long it takes until text has gone by (in preview) to use as a delay after overlaying in each time one changes the content
pretty simple basically
xun
#3 Posted : Monday, August 17, 2020 10:30:41 PM(UTC)
xun
Germany
Originally Posted by: doggy Go to Quoted Post
The hard part:
sounds good .. i will try it .. thx.
The easy part:
and this sounds not so good ;) ... i know the len of the text a short time before i will use it. So not enougth time for me to "time-stop" the len. So, its better to calculate the time or the position. But for the position i need a "gettextleninpixel function". A simple (charwidth * textlen) is not enougth if the font is not fixed len. (Or i must build up a function what do that for me)
i never use the script-part of vmix before. Did u have a litle example for me to do this calculation?
THX.
JimJim
XUN
#4 Posted : Monday, August 17, 2020 10:34:56 PM(UTC)
use mono spaced font ;-)
also i forgot to mention to take into account the fps of your setup for the calculations
xun
#5 Posted : Monday, August 17, 2020 11:38:25 PM(UTC)
xun
Germany
:-) ... i can't use monospaced font's .. the font is a customer specification.
JimJim
XUN
