gpdipalmerahtimur
#1 Posted : Friday, August 14, 2020 1:37:46 PM(UTC)
gpdipalmerahtimur
Indonesia
I think it is good if we have a function that can Turn Off all four Overlays without messing with Stinger 1 and 2 (Overlay 5 & 6). For example if I want to get rid all overlay (Logo, Social Title, Name Title etc.) without having to define 4 trigger actions (OverlayInput1Off, OverlayInput2Off,OverlayInput3Off, OverlayInput4Off).
Thanks in advance.
elvis55
#2 Posted : Friday, August 14, 2020 3:29:30 PM(UTC)
elvis55
Switzerland
OverlayInputAllOff
gpdipalmerahtimur
#3 Posted : Friday, August 14, 2020 8:31:38 PM(UTC)
gpdipalmerahtimur
Indonesia
Originally Posted by: elvis55 Go to Quoted Post
OverlayInputAllOff
Hi Elvis,
Thanks for pointing that out, but have you tried it with Stinger 1? Please refer to DWAM comment on this Thread.
elvis55
#4 Posted : Friday, August 14, 2020 9:11:23 PM(UTC)
elvis55
Switzerland
You keep opening new threads to practically the same problem! Why don't you stay in the previously created thread.
Then how am I supposed to know that you know the OverlayInputAllOff function. Just fill up the whole forum !!
thanks 1 user thanked elvis55 for this useful post.
doggy on 8/14/2020(UTC)
gpdipalmerahtimur
#5 Posted : Saturday, August 15, 2020 8:07:39 PM(UTC)
gpdipalmerahtimur
Indonesia
Hi Elvis,
This is not a problem, this is a feature request that needed because OverlayInputAllOff applies to Stinger 1 and 2 or should I request a new feature in GENERAL thread?
#6 Posted : Saturday, August 15, 2020 8:27:10 PM(UTC)
Its called OverlayInputAllOff
As they are part over overlays that's how it is.
The ability to specify each individual overlay just makes is flexible (stringers, shortcuts, script) and only takes one moment to set and then one is done (or do you intend to constantly change your shortcuts and triggers during a production?). Other than that it's just a slight inconvenience when preparing like taking multiple sips instead of one gulp
btw when defining similar triggers , you just change a little to the previously defined one and add it , no need to fully define it each time
And why not trigger the stinger AFTER you take your overlays of first ?
gpdipalmerahtimur on 8/15/2020(UTC)
