katalizt
#1 Posted : Wednesday, August 12, 2020 11:41:23 AM(UTC)
katalizt
At my church we have been operating vMix remotely using Anydesk. We've done this extensively the past five months, but this weekend we started having a problem. Whenever we connect or disconnect from Anydesk, if vMix is selected on the remote computer, a specific input gets automatically placed in Program. It's as if we had clicked CUT directly on Input 5. (If I close Input 5 it will just do the same thing with a different input.)
This only happens when vMix is the currently active window, if there is another program selected nothing happens.
I guess vMix must be erroneously receiving a keystroke or a click or something whenever an Anydesk connection is established or closed. But I don't have any keyboard shortcuts set up that would have this effect, and it happens even if Input 5 is not currently visible on screen. We've uninstalled and reinstalled Anydesk and that didn't help.
What could be causing this?
sunkast
#2 Posted : Friday, August 14, 2020 8:19:37 AM(UTC)
sunkast
I am having the exact same issue. Every time I move from the AnyDesk session window, to any window on my PC, shortcuts activate on their own. If I remove the shortcuts, this stops happening.
This post also seems to be talking about the same issue. I have no idea what is going on.
sunkast
#3 Posted : Friday, August 14, 2020 10:36:23 AM(UTC)
sunkast
I tested 2 other version of of AnyDesk. I had 6.0.7 installed so I downgraded to 6.0.6 and still experienced the random triggering of shortcuts. Installed 5.5.3, and this behavior went away. So something in version 6 of AnyDesk changed and now conflicts with vMix shortcuts.
thanks 1 user thanked sunkast for this useful post.
katalizt on 8/14/2020(UTC)
katalizt
#4 Posted : Friday, August 14, 2020 12:33:13 PM(UTC)
katalizt
I looked into the keyboard shortcuts, turning them on and off one by one, and the specific behavior I was seeing was three shortcuts getting activated at once. I disabled all the shortcuts as a temporary fix.
I'll try downgrading anydesk. Thanks!
#5 Posted : Friday, August 14, 2020 4:07:53 PM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
AnyDesk will activate the F1-F12 keys when logging on or switching windows
so best to make sure no shortcuts use these keys.
eduardocfs on 8/19/2020(UTC)
sunkast
#6 Posted : Saturday, August 15, 2020 12:56:49 AM(UTC)
sunkast
AnyDesk version 6 is activating more than just the F1-F12 keys. Practically every key is activating now with the exception of the number pad keys. I had a shortcut set up to start recording using the R key, and that kept activating. Changed it to A, it still activated. Same for every key in the number row at the top of the keyboard.
katalizt
#7 Posted : Saturday, August 15, 2020 6:40:50 AM(UTC)
katalizt
Same here. My shortcuts were on numbers, letters, and spacebar. All were getting activated. We've downgraded it to version 5.5.3 as you said and it's working perfectly.
