vMix Call
Vmix call Audio Routing
Joined: 6/24/2020(UTC) Posts: 14  Location: BROOKLYN Thanks: 6 times
I am routing one of the submixes (A-G) to Master Audio. I see & hear it everywhere I have the master going except in the Vmix Call Audio Return? All inputs punched directly to Master get through fine.
At a loss why this is happening. Help!
John
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Quote:Note: vMix Call Master/Headphones audio excludes any buses sent to master using this method as doing so would prevent mix minus from working correctly. https://www.vmix.com/help23/Mixer.html
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ jcw718
To the best of my knowledge, that is essentially by design since that is part of the mechanism used for the internal mix-minus of vMix Call. As per dmwkr's link: "Note: vMix Call Master/Headphones audio excludes any buses sent to master using this method as doing so would prevent mix minus from working correctly."
vMix Call
